| Message |
I've been chasing a misfire on cyl 6. Happens only at idle, the plud appears to be burning a little cooler than the others, but the plug is clean. No sign of excessive oil on the plug. I did compression and leak down and 6 is in line with the rest. Injector ohms out fine, connection with the harness is good, I'm starting to wonder if it just isn't firing right at low loads. Any thoughts?
-Dan "Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse." "'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr "full alphabetic boost mode" - ChristopherTheOne "Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines |
